Wire! mod question
Old Oct 3, 2009 | 11:47 PM
99Zeeeeeeeeee28's Avatar
Default Wire! mod question
Hey guys, I've been thinking about hiding my wires for the PCM under the wheel well like many of you but my front tires rub when turned in or out. Is it safe to do this or would the wires get crushed?
Old Oct 3, 2009 | 11:58 PM
lemons12's Avatar
It is !Wire mod.
You will be fine just tuck them up nice and put fender well back in.. I wrapped the connections in electrical tape on mine for extra protection, just in case.
Old Oct 4, 2009 | 12:00 AM
latindragons's Avatar
Don't the wires go in between the well and the fender?? There shouldn't be any rubbing at all if that's the case. Then again, maybe I'm totally mistaken haha
Old Oct 4, 2009 | 12:05 AM
hlaalu's Avatar
Unless the TOP of your wheel rubs up against your well on that black mud guard or whatever it's called, you will be fine. The wires tuck up in between the black thing and the wheel well.
Old Oct 4, 2009 | 12:08 AM
Ok, thanks for the responses guys. Also, is it ok to use double sided tape instead of velcro?
Old Oct 4, 2009 | 12:17 AM
lemons12's Avatar
Even if it rubs at the top it is ok... There is plenty of room to not squish the wires.
Where are you using tape and/or velcro?
Old Oct 4, 2009 | 12:45 AM
Doesn't the one how-to guide say to use the velcro to keep it up against the wheel well?
Old Oct 4, 2009 | 12:48 AM
lemons12's Avatar
Not a clue...
ack up the car on the front right.. take the fender well out and wheel off.. take your circular hole cutter thing or whatever the hell it is called and drill your hole.. run your wires through the hole and to the other side.. wrap connectors with electrical tape.. use zip ties to hold them up.. not sure if there is pre drilled holes there or not (been a while since i have had to do it on a car i had).. if not drill two very small holes in a non noticeable spot (up against the body not right on the hump) and zip tie them there.. put fender well back on.
You are done.
Old Oct 4, 2009 | 12:49 AM
lemons12's Avatar
Just start doing it.. It is self explanatory.. Take your time and it will look very clean.. Just use your head a little bit.. It really is simple.
Old Oct 4, 2009 | 01:04 AM
01SOMSS!'s Avatar
wrap the wires with saran wrap.
Old Oct 4, 2009 | 02:38 AM
WhiteRhino's Avatar
I depinned the wires from the connectors on mine. So I wouldn't have to make a huge hole. It's time consuming, but I think it looks nicer. Then I used duct tape to hold the wires up. Before I repainted mine, I welded all the extra holes shut.
Old Oct 4, 2009 | 05:33 AM
hlaalu's Avatar
i wrapped my wires up in tape, they were tight enough i didn't even use velco.
