need help removing...
Old Jul 24, 2002 | 08:42 PM
unfcamaro's Avatar
Default need help removing...
gauge cluster to install my macewen gauges. The directions say to just pull it out but it doesn't seem to want to come and I don't want to pull too hard and mess anything up. Anyone that has done this have this problem?
Old Jul 25, 2002 | 09:18 AM
Xsta Z 28's Avatar
Default Re: need help removing...
I assume you have everything but the cluster removed, IE the factory outside bezel/frame, and all that is left is the clear plastic cover and the guage pod.
IF you are at this point, the guage pod is held in with four 7mm or 8mm bolts, two on top and two on the bottom. Once those are removed, the cluster should pull right out. You may need to twist the top down a little to get the cluster over the steering column.
Hope that helps.
