Blue Gauges LEDs problem
Here's mine:
http://www.autoaccessorystore.com/ho...=detail&id=729
Just install one of these kits and have super bright needles regardless of anything else.
From the website;
Glow Gauge Needles Kit
* Mini ultra bright LEDs.
* Unique custom look.
* Compatible for all vehicles with lexan based needles.
* Brightness is adjustable with a dimmer switch.
* Installation instructions included, professional installation required.
* Factory needles are used with this kit. New needles are not included.
This kit will fit the following
Needle Variations
1 Large Needle & 2 Small
2 Large Needles & 2 Small
2 Large Needles & 3 Small
2 Large Needles & 4 Small
2 Large Needles & 5 Small
Lexan needles are needles that glow at night from your lights behind the gauges. Non-lexan needles do not glow at night. 80% of the vehicles that were manufactured after 1990 have lexan based needles. 95% of the vehicles manufactured after 2000 have lexan based needles. This kit is installed underneath of your factory needles and provides an ultra bright light which makes the needles glow from your old dull color to the new ultra bright color. The kit is powered by a 12 volt system.
http://www.ledgauges.com/id26.html
I haven't done one of those odometers yet but it looks like they just pulled off the red smd leds and soldered in a few 3mm leds.
I'm using the same WLED xHP6 LEDs, and I have NO problems! I'm actually almost done with my preliminary tests on different needles I'm going to start manufacturing to fix this very problem.
Do you by any changes have 6LE overlays? Here's my cluster with my new improvments.
Is it like the clear film you could get at a Hobby Supply store?
Does anyone know if Ultra-Violet LED's have ever been tried in the gauge cluster or interior?
I'll keep you guys posted.
Worked out perfect in my Firehawk, though I did have to look at Camaro gauges afterwards, lol
Just FYI, the reason my needles have a blue tint to them is because I chose "cool white" over "natural white" The "cool white" looks good throught the overlay, but the absolute clearness of the needle shows it real color, a lightblue hue.
My neon needles are going in next for a trial. (Here's a 1st sneak peek....and these pics dont do them justice)
