carpet dye?
Old Oct 13, 2009 | 12:57 PM
futuref-body's Avatar
Default carpet dye?
my carpet is looking a bit on the gray side instead of the black i wish it would be. is there a dye or something i could use to darken it? or i would just have to buy new carpet?
Old Oct 13, 2009 | 02:17 PM
Havok2's Avatar
carpet & vinvyl spray paint. works good when i did mine
Old Oct 13, 2009 | 04:03 PM
redbeauty2012's Avatar
do you have to remove the carpet to do this or can you tape everything off? will it leave a bad odor and how well does it dye it? anyone done this?
Old Oct 13, 2009 | 04:08 PM
GOR1LA's Avatar
i would think the easiest way would be to remove it or atleast take the seats out/ panels so you can get everything dyed/painted. I'm thinking about doing this (should have done it when i did my sound deadener).
Old Oct 13, 2009 | 07:15 PM
nice. ill probably do it when i sound deaden my car. does it leave the carpet soft or does it get hard when it dries?
Old Oct 13, 2009 | 08:50 PM
bryanracing95's Avatar
I would just replace the carpet, I have been doing car interiors for over 8 years, the only thing dye is good for would be for doing molded trims, dash, etc. Carpet is a heavy wear item and rattle can dye isnt going to hold up
Old Oct 13, 2009 | 10:10 PM
oh yeah...i could see that easily. but the part that would wear the most-it will be getting covered with custom floormats
Old Oct 14, 2009 | 05:04 AM
98Z2885's Avatar
If you buy anything dont waste your on duplicolor or krylon. SEM is the best. I have used them all and it is by far the best thing you can buy locally. I know Advanced auto parts has it.
Old Oct 14, 2009 | 06:16 AM
how hard is it to put the carpet back in and how is all the trim put back in i know how to take it off but i already have a couple pieces of trim that is not snapped back in place
