Burnout results
Old Dec 6, 2003 | 03:13 AM
FatZ28's Avatar
Default Burnout results
Well went to the track tonight and it was really cold so I smoked the tires pretty good to get them hot. Well this morning come outside to see bits of tire all over the car behind the tire. I got most of it off but some of it is caked on good. Is there anything I can use to get it off? Maybe tar removal? Any help would be great.
THX
Old Dec 6, 2003 | 03:31 AM
Gev's Avatar
Gev
If it's in the wheel well, keep it there, extra undercoating.
If not, you should give it a good wash, then scrb scrub scrub.
Old Dec 6, 2003 | 01:31 PM
wrencher's Avatar
wrencher
Lots of wax build up helps it fall off easy.
Old Dec 6, 2003 | 01:59 PM
Hawkn01's Avatar
WD-40 will take it off,but you will go through a few rags. Next time before you do a burn-out spray some Pledge furiture polish in the wheel wells and around the outside of the fender. When your done take it the car wash and it sprays right off. A good coat of wax also helps. I have tried different things and that seems to work the best for me.
Old Dec 6, 2003 | 02:39 PM
ta12sec's Avatar
Pam (nonstick cooking spray) works the best for me
Old Dec 6, 2003 | 03:47 PM
onyxxtreme's Avatar
also, before you do burnouts
you can try Vasoline
Ive rubbed it all over the areas behind the tires, and just spray it off the next day with a hose
ta12sec's suggestion will work just as well
Old Dec 6, 2003 | 04:19 PM
JackZ28's Avatar
Thunder Racing sells burnout guard. I would recommend using THAT, since it's made for it!
Old Dec 7, 2003 | 02:14 PM
AZLS1's Avatar
Leave it on!!!
Old Dec 8, 2003 | 09:15 AM
Bharnz's Avatar
If it's a factory finish clear coat, you can use lacquer thinner. but if it's been repainted, DONT, you also might try a bit in an unexposed part of the car just to test this first,. but it does work.
Old Dec 8, 2003 | 01:26 PM
SilverGhost's Avatar
Motorboater
WD 40 works, only thing that sucks is that is turns it into a drippy mess that will stain the ground so make sure you put some newspaper or shitty towels down when doing it.
I've found that Simple Green degreaser does the job without making the gooey mess that stains.
Old Dec 8, 2003 | 01:42 PM
Hawkn01's Avatar
Silver, I just spray it on a rag and wipe, trouble is that you go through alot of rags. The burnout gaurd they sell is what I found to be a big drippy mess,I don't like that stuff at all. The Pledge furniture polish has worked the best for me so far.......I imagine Pam cooking spray would work also but never tried it.
Old Dec 8, 2003 | 01:54 PM
Addicted's Avatar
I wouldn't do this, you'll take off the rubber fast and easy but each time you do it you take off a very small amount of clear coat, as you know our cars don't have much clear coat on them. I've always used Prep Sol. to take massive amounts of rubber off after burn out's in my brother's car, the side effect is it will also remove ALL previous wax.
Old Dec 8, 2003 | 04:33 PM
Motorboater
My bumper from the wheel well back has no clearcoat left on it anymore..been that way for a couple years now, I've never used anything to clean the rubber off that would eat it away, I think its just from so many times of having hot rubber and what not thrown at it, prolly ate the clearcoat off.
my car is getting totally repainted this month so I am going to have to try some of these ideas in this thread from here on out to keep it from happening again to me.
Old Dec 8, 2003 | 09:34 PM
onebadz's Avatar
Use some PAM cooking spray, always worked good for me.
Wes
