Grill badge question.
Old Oct 27, 2009 | 01:49 PM
armyboyatc's Avatar
Default Grill badge question.
Im sure you guys have answered this before but I couldnt really find what I was looking for in the archives. I need to know where I can get a White SS badge from to put on my new billet grille and also how you get the badge to stay on the grille. Thanks.
Old Oct 28, 2009 | 01:46 AM
9WhiteCamaro9's Avatar
i would just buy one sand what area you want white then paint it then after thats said and done just take some type of really good glue type stuff like gorrila glue, jb weld or something like that then just glue it on
Old Oct 28, 2009 | 10:23 AM
armyboyatc's Avatar
I ordered some white SS badges so im good on that and thanks for the advice! I didnt know if they used some bracket deal or something. I can to simple glue stuff!
Old Oct 28, 2009 | 12:29 PM
camaross333's Avatar
Default ss grill emblem
theres different year ss, they have a diff angle, you need the 1969 ss, hope that helps, abby
Old Oct 28, 2009 | 01:28 PM
98Z2885's Avatar
67-69 ss emblems will work. I played around with a emblem off of my 67 and it will work too. Everyone uses the 69 emblems though.
Old Oct 29, 2009 | 10:40 AM
Havok2's Avatar
yeah, some bades (hope the ones you bought) come with pins that go thru the grille, then tbe plate you place in the back to lock it in place.
Old Oct 29, 2009 | 10:41 AM
Havok2's Avatar
mine, i sprayed it white, then filled in the inside black
Old Oct 30, 2009 | 06:52 AM
Camaro Junky's Avatar
I used the clear epoxy from any car parts store. I set the grille on the badge and let the epoxy build up between the grille and behind the SS badge. It wil not come off.
Old Oct 30, 2009 | 10:47 PM
rob69zombie's Avatar
I actually used a 67-68 SS emblem which is not as sharp of a 'V' shape as the '69 emblem, and it sits perfectly flush with my billet grille. There are only a couple of my style grille set-ups around my area and they're all '69 emblems that fit like **** or they had to be dremeled down to sit flat. As for holding it on, it should have 2 posts on the back that fit in the grille held on by a retainer plate and a couple of speed nuts.
