Centerline warrior/Hoosier QTP pics
I just got these tires mounted on the rims. Put two of them on the car to take some quick pictures.
The rear rims are 15x8.5 with 5" back spacing.
Fronts 15x4 1 3/4" backspacing.
Rear tires Hoosier QTPs 27x11.5x15
front tires Moroso DS2 Front drag 26x4.5x15
ZERO grinding of the calipers. These rims just bolted right on. Im a sucker for the easy way. Only problem is that the balance weights are going to have to be moved a little closer to the inside of the rim on the back rims, they were rubbing just a little.
Ahh the link http://imageevent.com/lastws6
Like all rims these just might not be to some peoples tastes.
Props to Barry at QTP for getting this setup for me. Thanks to jason at fbody central for the 27" Hoosier recommendation.
Re: Centerline warrior/Hoosier QTP pics
I have a coupld of questions.
1. Did you use a spacer for the front or grind anything?
2. Did you install longer studs?
3. Any other weird things happen with those??
I want a set of Bogarts but if these wheels bolt right on that would be a hella lot better than paying 300 bucks per wheel(for the back) and 200(for the fronts)
Josh S.
Josh S.
