Need help with removing back seats
Old Sep 4, 2002 | 01:56 AM
1badls1bird's Avatar
Default Need help with removing back seats
Okay, just wondering how you remove the back seats in my TA???? The seats look straight forward, it is the belts I am more worried about.
Tell me if this is correct, the bottom of the seats come out with one bolt below the seat (more in front of it really)? How does the back rest part of the seat come out ( the one large picece)?? And then then the seat belts? Thanks!
Old Sep 4, 2002 | 09:31 AM
Xsta Z 28's Avatar
Default Re: Need help with removing back seats
The seat buns are removed by removing the blot that is facing the front of the car, it is something like a 10 or 13 mm, it has been a while.
The seat belt loop is attached to the side of the seat back with some torx bits. They are loctited into the seat and can be very difficult to remove, just use the correct size torx and be patient they will come out - eventually.
The seat back, once the seat buns are removed, at the hinge points there are tow 10 or 13 mm nuts holding the seat back in.
VOILA! You are done.
