Amazing Buffable Rattle Can Paint!
I used about 2-3 light coats followed by 1 heavy coat as it looked stripey and didn't seem like it was going to dry evenly. The heavy coat did the trick, but my dad was doing some dusty work and made it rough afterwards, either that or it was just from spraying heavy.
I was okay with that but the next day I decided to try something. I grabbed some 200 grit I had laying around and tested a little spot and hand polished to see how it would go...result were decent so I took the plunge and sanded it like it was the real deal, thoguh still being careful as I was unsure of how it would take the heat from buffing and how much material was there. So I bring out the compound and cheap buffer:
First results:
A little better:
and later I'll polish them at work
Here's some more shots of the other side to compare
Funny thing is that pad on there isn't really a pad, it's supposed to be like an interface pad for a terry cloth like pad to be put on it like a girl's scrunchy, but it looked like a foam polishing pad and it works
. I could probably go further, But I'd rather have more paint on there.
