Aftermarket Seat Brackets (help)
)im THIS close to grabbing some corbeau brackets, not even knowing if theyll fit these seats, but i figured id see if anyone had a lead for me.
im pulling out 6 way '00 seats, got the pass side in and its too far (3/4") to the right, and the drivers side the brackets curve up too much to match.
does someone have some insight here?
Ill show some goods to help spur on my troubleshooting.
OUT
IN (for looks)
IN (actually mounted, as stated, not to standard)
Someone help so i can move on to wrapping this craplastic interior
other option is to drill the factory brackets into the seats, let em hang, or try somethin new and exciting (no ideas yet. lol)
For the install, did you check out my write-ups?
http://6litereaterdesigns.com/forum/...php?topic=34.0
The passenger side is actually gonna be fine doing that (after more adjustments), but was your drivers seat fully adjustable? im having compound issues there since the factory sliders are recessed so the factory seats sit lower
EDIT: also mark, if you wanna throw them in with my gauges that works, i think those are going out soonish? (gp ends on the 5th right?)
the bolts push the sliders to the side
and the brackets hit the sliders where the factory seats were raised like 1/2" off the mounts (new seats are flat bottomed)
For the weird crooked bolt just wallow out the hole on the slider more so there is enough plate to flatten it out...
seats are in. I need to finish fitting the plastic pieces on the aftermarket seats, then theyll get wrapped (which is why the boot/wheel button are missing)
i think this weekend im doing some foam lumbar support and down the road ill be doing some suede stuff, but theyre sweet.do you prefer the seatbelt guides to just putting them through the holes? (i havent yet cause i dont wanna pull the panel and cant get the cap off the bolt on the bottom)
