C6 shift knob
Old Mar 8, 2010 | 04:04 PM
caseypryan's Avatar
Default C6 shift ****
Does anyone know where to get a C6 style shift **** for an F body? The 6 speed not the auto.
Old Mar 8, 2010 | 04:42 PM
black_sheep454's Avatar
I too would like to have a c6 six speed ****
Old Mar 8, 2010 | 04:45 PM
vicouSS00's Avatar
Me too.
Old Mar 8, 2010 | 04:54 PM
Unertl42's Avatar
order one online, and all you have to do is drill it and tap it with a 14.5mm tap. easy
Old Mar 8, 2010 | 06:19 PM
caseypryan's Avatar
Order online from where? And I'm sort of looking for something reasonablynoeived not dealer costs
Old Mar 8, 2010 | 06:20 PM
DoomSlayer's Avatar
There is a website that you can order the ***** that are already fitted to fit the fbods. I ordered one about a month ago for around 100 bucks. I will look at my invoice tonight for the website.
Ok here is the website... hope this is what you guys were looking for...
http://www.gscreationsllc.com/produc...6a2f9d07759cd8
Also BEWARE! The C6 style shift **** will sit higher then the Hurst or SLP shifters... I believe this is due to the threading. So you may not like the look... check my pic out of the shifter on my bird. Pics are at the bottom.
https://ls1tech.com/forums/appearanc...t-dd-ever.html
Old Mar 8, 2010 | 07:33 PM
therobman's Avatar
dont order from there its a rip off when i had my c6 **** order this one
http://www.corvetterecycling.com/pro...20100125-3.htm
the inside of the **** is hollow plastic so take you short stick put it in a vise grip to lock it and turn the **** on it will thread itself the c6 **** sits high because the stick wont go to the top of the **** i had my short stick cut in the middle with an 1"-1 1/2" taken out and welded back together heres how mine looked
Old Mar 8, 2010 | 07:37 PM
mklinger's Avatar
Default Shift *****
Have a look at the sweet ***** over on the MGW website.
www.mgwltd.com
I think if you call they may tap these to whatever size you need if they don't have it already.
Old Mar 8, 2010 | 07:54 PM
I'm gettin the mgw shifter, wonder if the c6 would be tall on it
Old Mar 8, 2010 | 08:52 PM
Johnny-LT1-runner's Avatar
Rockstar
Seen em on ebay for 50 before.
Old Mar 8, 2010 | 09:43 PM
DoomSlayer's Avatar
Not to try and take GSCreations up or anything... Their item was as stated. I got the shifter in the mail and screwed it directly on. Price may have been a little high... but honestly I would rather pay a little more than have to screw with it.
Old Mar 9, 2010 | 07:17 AM
BTL FED's Avatar
I have the same GS Creations ****, it is works great just screw it on
Old Mar 9, 2010 | 05:03 PM
99zee's Avatar
Got the same one a couple years ago. Perfect fit
Old Mar 9, 2010 | 06:17 PM
mklinger's Avatar
I am using an MGW shifter that I mated up with one of the MGW Mustang shift *****.
Old Mar 9, 2010 | 09:44 PM
Irish350's Avatar
id be interested to see that in the car
Old Mar 10, 2010 | 01:03 AM
jb98camaro's Avatar
i found mine on ebay brand new for 40 $ shipped. the reason the **** wont go on is cuz of the plastic tab half way in the shift ****... i just drilled that out and it worked perfect. i got the **** on all the way and the **** is at the perfect height that i want it at
Old Mar 10, 2010 | 04:13 PM
caseypryan's Avatar
^^was your shift **** meant for an F-body or a corvette?
Old Mar 11, 2010 | 07:40 AM
jb98camaro's Avatar
for the corvette
Old Mar 12, 2010 | 07:32 PM
DoomSlayer's Avatar
So just to clarify... there is a plastic tab half way up and you just drilled it out and it screwed down further. I might have to try that.
Old Mar 13, 2010 | 01:05 AM
jb98camaro's Avatar
yup exactly. just get a light and look down inside the ****. or feel in there with your finger. just be careful if you are going to drill it out that you dont go to far and to the end of the **** or you could mess stuff up... or go right through. i just did mine a little at a time and kept checkin it till it was just right. worked perfect for me
