Removing Side Vents
My questions are...does this look good? If so, should I take my dremel and shave off the lips so it's more smooth flowing? I know if I do this, the fiberglass will show. I plan to take touch up paint to the newly exposed areas.
Let me know
theres not really anything you can do functionally, but im not against ditching the factory honeycomb theme where applicable.
the hood grills can look good removed. as long as you shave the lip so there is a completely smoothed opening, and there is nothing showing behind it.
would be cool, but a whole lot of work for very little actual functionality (if you had tubes going to the front brakes from the front bumper you still wouldnt get any gains unless you actually road raced. rear brakes do less)
