Wire Mod Issue 2002 firehawk
Old Mar 24, 2010 | 02:07 PM
logicsound's Avatar
Default Wire Mod Issue 2002 firehawk
Ok so I guess I am an idiot or have something no one else has.... I am trying to do the wire mod and I have 2 wires and a cable I think that does not disconnect. I have traced the green and orange twisted wire and it goes all the way around front to the drivers side and then I lose it. Please see pics. Car is a 2002 Firehawk 6speed
In red is the cable and twisted wire I am talking about.
in red is the cable, it goes under the car.
Thanks
T
Old Mar 24, 2010 | 02:11 PM
Trans Am Jam's Avatar
I don't remember seeing that on my 00 Trans Am.
Old Mar 24, 2010 | 02:14 PM
bigj2717's Avatar
I haven't seen those first 2. The last one looks like it could be the abs wires that go to the hub and you can just unplug it run it through the hole you make and plug it back in
Old Mar 24, 2010 | 02:16 PM
SVThis's Avatar
mine had that and when i went into further investigation i found this under my car
http://www.youtube.com/watch?v=liBPkRys3Vk
Old Mar 24, 2010 | 02:18 PM
=Tac='s Avatar
^^ you found html under you car?
OP, that wire on top, you sure theres not a connected inside part of the wire loom?
Old Mar 24, 2010 | 02:25 PM
slammed1500's Avatar
that goes down 2 the control arm and plugs in on the k-member
its 4 the ABS sensor on the hub
Old Mar 24, 2010 | 02:36 PM
crimson_bird's Avatar
can/how do you remove it
Old Mar 24, 2010 | 02:38 PM
bigj2717's Avatar
Just take off your tire and you'll see where it plugs into the back of the hub. Just unplug it and reroute it
Old Mar 24, 2010 | 04:15 PM
undo the plug on the k member and there is a lil wire fastener on the frame rail next 2 the header/manifold, undo the wire from it and pull the wire up out of the way
and then reroute
logicsound's Avatar
Default Thanks!
That was it, took off the wheel and then unplugged from hub, and looked closer and saw that other "cable was a vacuum line unplugged and all set....
perfect timing, posted this, went out did the tranction control move and now I am all set...
Thanks
T
Old Mar 24, 2010 | 04:26 PM
=Tac='s Avatar
Thanks
T
Cool man, post some pics once your done!
Old Mar 24, 2010 | 10:36 PM
02CamaroSSLE's Avatar
Old Mar 25, 2010 | 03:43 PM
logicsound's Avatar
All done, just need to fill in those holes, paint and clean up that rust...
Thanks
T
Old Mar 26, 2010 | 12:45 AM
BlkBird2000's Avatar
Looks good dude. Make sure those wires are protected where you cut that hole at. I didn't protect mine and after awhile the sharp metal carved it's way through the wire loom and touched the wires. I started my car and the starter kept turning the engine over even when it was running. Turned the car off and it still kept doing it. I freaked out and just unplugged the battery. It blew some fuses then wouldn't start. I learned the hard way about making sure those wires are protected.
Old Mar 26, 2010 | 08:29 AM
logicsound's Avatar
Thanks!, Yep I will be getting a grommet and protecting those wires this weekend. Got the old "Dinner is ready!!" yell last night so I had to stop..
Thanks
T
Old Mar 26, 2010 | 09:58 AM
ninjai_ruken's Avatar
BS We all know we cant get these cars up to 88mph
Old Mar 30, 2010 | 06:39 AM
logicsound's Avatar
Default All Done!
All Done, just need to do a little touch up
Old Mar 30, 2010 | 06:57 AM
billyb's Avatar
good job , need to do the hood latch cable now/
Old Mar 30, 2010 | 03:48 PM
oddwraith's Avatar
Is this mod of any benefit for keeping the wires dry as well as simply looking better (and that does look a whole lot better ) , just wondering if mine get wet sometimes where they are?
Old Apr 4, 2010 | 02:52 PM
logicsound's Avatar
I would think so, I wrapped mine in plastic wrap and then electric tape. They are also tucked up perfect behind the shroud.
