DDM Tuning
Old Oct 8, 2010 | 01:03 AM
  #41
Camaro Ryder KV's Avatar
my ddm 880 didnt come with a plug, just a blue and black wire. i dont want to jerry rig it. what do i do??
Old Oct 21, 2010 | 09:52 PM
  #42
PrestonYale's Avatar
I'm Going to be ordering the 880's From DD Tuning for my Fogs with the harness, Do I need an Error Eliminator or the Adaptor cables (H1/H7 to 9006) as well?
I will be running the BBS kit lows and highs with the fogs, will that be a problem?
Old Oct 21, 2010 | 10:04 PM
  #43
Dont you need (2) Kits? 1 Kit for each light correct?
Old Oct 22, 2010 | 01:06 PM
  #44
99huggerorangeZ's Avatar
You don't need the error eliminator or the adaptor cables. 1 kit includes everything you will need minus the relay harness(sold seperately).
Old Oct 23, 2010 | 06:42 PM
  #45
99TransAm666's Avatar
Im running some H1's 55w with the slim ballast from DDM for my headlights. Ive been running them for a couple months now with NO issues at all. And im using my old headlight housing. I just cut out the old light bulbs and put the new bulbs in.
Old Oct 23, 2010 | 10:57 PM
  #46
Sarge91's Avatar
Had my 6k low and fog for about 4 months now, as a dd, i probably tun them on 4+ times a day.. no problems here. HID's for now on!!
Old Oct 30, 2010 | 06:22 PM
  #47
LE35thSS's Avatar
ok so here's what i plan on buying:
9006 55w 5000k
9005 55w 5000k
880 35w 5000k
that should be fine correct? is it an absolute must that i buy the hid harness as well? after reading this post i saw mixed reviews about them.
Old Oct 30, 2010 | 06:38 PM
  #48
bad_408_vert's Avatar
I 'd say you definitely need the harness, I'm 100% that 3 kits would put stress on the stock wiring.
Old Oct 30, 2010 | 06:58 PM
  #49
LE35thSS's Avatar
will one harness do the trick or one for each set?
Old Oct 30, 2010 | 09:51 PM
  #50
I'm not sure, I just have 2 HID kits in total for fogs and Lows.
I only used one harness for the fogs and the lows are just plugged into factory harness.
Maybe someone else can chime in.
Old Nov 2, 2010 | 09:27 PM
  #51
whitdog54's Avatar
Gonna bump this back up
Just got my stuff in for low beams and fogs. I didnt use the wiring harness when I had my firebird so hiding all the wiring away was easy. But with this harness it seems like its gonna be difficult to hide the wiring. Anyone have pics of there wiring or tips of where to run the wires to make it look like clean install.
Also these 9006 bulbs dont sit very well in the housings I feel, and how do you get that damn plastic protector thats around bulb off, the lower piece? Did HID install in my firebird in like 25min, somehow im making it too complicated though with the camaro
Old Nov 10, 2010 | 12:14 AM
  #52
do i need the dual in dual out HID harness? or adapter cables(h1/h7 to 9006)? i know i dont need the error eliminator.
Old Nov 10, 2010 | 11:36 AM
  #53
anyone??
