Wiring halo's (2002) to a switch....
Old Mar 30, 2010 | 09:44 PM
Mr. Luos's Avatar
Default Wiring halo's (2002) to a switch....
I did a quick search, didn't really come up with a good answer. But I suck at search too....
Anyways, what type of power supply is needed to safely run the halos?
Planning on running a separate switch in the cab of the car for just the halos. What size fuse if I run straight off the battery??
Or what interior power supply would work well to supply proper voltage/power to run them correctly?
Also, the halo wiring kit comes with two red wires on each one. One ground and one hot I assume?? Does it matter as long as they are matched from one side to the other??
They are the EBay lenses.
TIA!
Old Apr 2, 2010 | 12:12 AM
Mr. Luos's Avatar
Nothing in 48 hours?
Anyone done the halo's with a switch in-cab?
Wiring isn't a problem for me, just not sure what kinda power they need.
Old Apr 2, 2010 | 12:41 AM
bobbyd's Avatar
you are correct 1 is ground and 1 is hot.
just get a ground and run the power from the stereo or from somewhere where its getting power.
you can only plug them in one way. not hard at all man. basictly like hid's if they dont work plugged in one way swap the wires around and it will work.
Old Apr 2, 2010 | 09:06 AM
TheLSgun's Avatar
I grounded them with the fuses under the hood. Then for power i tapped into the cigarette lighter since my switch is right below it.
Old Apr 2, 2010 | 02:34 PM
AZ2ENVY's Avatar
Hey Curtis I can help I've been doing 12V & 6V vehicle electrical
Systems for over 10 years . Give me a buzz
Old Apr 2, 2010 | 03:16 PM
WICKIDSIX's Avatar
My halos were the same way. (two red wires) Either it doesn't matter or I got both right the first time. As far as the power for them I ran mine off the parking lights but If you want a switch just use the cig lighter wires.
Old Apr 2, 2010 | 09:03 PM
Mr. Luos's Avatar
Thanks fellas!!
ZL1LT1...I can handle wiring without a problem, just wasn't sure what amount of power the source would require to run them. Likely going to use the lighter.
Thanks again!
Old Apr 2, 2010 | 09:47 PM
99'CajunFirehawk157's Avatar
fOG hALOS?
Old Apr 2, 2010 | 09:55 PM
SparkyJJO's Avatar
Your HVAC confuses me. Set to max AC with the temp turned all the way hot?
Old Apr 2, 2010 | 11:34 PM
camarox302's Avatar
Did pretty much the same thing mine are wired on a relay, to a stock fog light switch.
