Clear Conners
Al
No moisture yet and I have changed both of my light bulbs about 6 months ago. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
I went throught bulb after bulb being burnt out because of moisture...and i HATE driving down the road with a burnt out driving light.
the fix: take them out, and drill a small hole on the inside bottom...I actually drilled 3 holes in each one.....make sure that you get in that bottom corner (they slant)...right in the middle of the corner.....it works.....you obviously can not see the holes drilled....I have not had a single drop of moisture, or a burnt bulb since I have done this.....back in may.
Hope this helps.
-chris.
<strong>I used to have bad probs with this....infact you could say i actually accumulated puddles of moisture in their...I have the answer!
Hope this helps.
-chris.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The OEM sidemarker lights in my 1998 Lumina LTZ always filled with water, so I did the drill mod and it worked great, I put one hole on the top as a air inlet and two down low for the drains, always are dry and never any condensation.
Do you have any pics of where exactly you made the holes? I have a passenger Clear that is constantly having a problem with moisture in the corner where the smallest bulb is closest to the fender.
I've tried filing down the warpage and used RTV to seal the rubber sealts on and still get water in there.. It's amazing <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Now.. If only I could subscribe and be email notified of this Post! <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
<small>[ October 18, 2002, 09:55 AM: Message edited by: StealthStalkerLS1 ]</small>
<strong>chrswr5,
Now.. If only I could subscribe and be email notified of this Post! <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No, I sure dont...Just take them out, and drill where it appears to be obvious....in the lowest part of the end corner, kinda at an angle in the curve. I also drilled a hole in the middle and at the other end...for maximum drainage...
Hope I have helped.
-chris.
One last question.. How bit of a drill bit are we talking?
<strong> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> Thanks Chris... and for the Email Notification.. haha..
One last question.. How bit of a drill bit are we talking?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I used a 5/32...but for no apparent reason, other that in my very incomplete bit set, eveything else was really small, or too big.
Thanks!
P.S. and i'm a goof for saying how bit of a bit.. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" /> Glad you knew I meant Big of a bit.. Doh!..
