What size led bulbs for window switches, headlight switch and steering wheel?
I need to know what size bulb to get for the window switches, door locks, steering wheel switches and headlight switch. I am wanting to change them to led.
check this thread out....
https://ls1tech.com/forums/appearanc...-led-list.html
not sure if it covers the steering wheel tho. but there is a thread for that too. i'll keep searching
Not sure there is a bulb number for those at all . Those tiny incandesnt bulbs are hard soldered to a circuit board . If I were replacing those with an LED I would used a flat surface mount smd LED . You will have solder and use proper resistors for them to function correctly .
Can you like to a flat surface mount SMD LED? I see millions of LED's on ebay
