aftermarket Firebird Headlights
Old May 13, 2010 | 02:58 AM
djkeene16's Avatar
Default aftermarket Firebird Headlights
aftermarket Firebird Headlights????
do they exist????
camaros have ton
Old May 13, 2010 | 03:03 AM
98PurpleT/A's Avatar
They have fixed headlight kits and BLS sell projector headlights and some people make there own
https://ls1tech.com/forums/appearanc...?highlight=bls
https://ls1tech.com/forums/pontiac-f...ird+headlights
Old May 13, 2010 | 03:21 AM
crimson_bird's Avatar
yes, they exist. but they all cost a **** ton of money...
you've got the BLS kit, as ^98PurpleT/A posted -$500-$800
you've got your breathless performance kit: http://www.breathlessperformance.com...53firebird.asp - $1100
or, as mentioned, you can make your own set up, which will require quite a bit of custom fab work, and a little knowledge of what you're doing. someone had a thread showing his custom designed fixed headlight projector set-up, not sure if he ever finished 100% though, and i forget what his thread title was
Old May 13, 2010 | 03:30 AM
djkeene16's Avatar
yeah thats it tho right thats 2 kits
Old May 13, 2010 | 07:15 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I'm not sure I'd call $500 for the BLS kit a **** ton of money considering that's the cost of the cheapest long tube header/ypipe setup, but they aren't ebay headlight cheap either.
For the added safety of better headlights, they are worth every penny and more.
Old May 13, 2010 | 09:31 AM
whitdog54's Avatar
Yes 2 kits, otherwise you can go HID set up using some new housings.
Old May 13, 2010 | 10:41 AM
TransWS6Am's Avatar
LMC truck! is what i got. every nice headlight. from a 88 gmc truck i think it is
