Rear View Mirror Install
I plan on doing a write-up during the process as well....
In the OTHER instructions it says that a CONSTANT power would drain the battery from the mirror from either the temp sensor or compass. I thought that the mirror lights were always hot because you can turn on the map lights at any time, even if the car has sat a while with the engine turned off.....
I'm gonna get a multi-meter and poke around under the dash and see what I find...
There is a diagram on the back of the fuse panel cover.
Post pics when you're done !
Cheers,
Rob (Bad30th)
I should be able to finish it up by tomorrow (w/pics), it's just been AFRICA hot here in Kentucky last couple of days.
