CME tape
Old Jun 21, 2010 | 07:57 PM
sheikss's Avatar
Default CME tape
What double sided tape do you guys recommend to use on this cme? The corners have a gap between the valance and the bumper.
Old Jun 21, 2010 | 07:58 PM
SSPerformance's Avatar
3m worked for me
Old Jun 21, 2010 | 08:13 PM
sheikss's Avatar
Was there a particular 3m you used? Did you get it at the parts store?
Old Jun 21, 2010 | 08:27 PM
i got it from a automotive finish store that sells paint and what not... it was a 3m tape worked good
Old Aug 7, 2010 | 11:54 PM
01SOMSS!'s Avatar
bump. I'm going to install mine soon.
Old Aug 8, 2010 | 01:37 AM
02CamaroSSLE's Avatar
i used 3m tape that 6le sent with it and it didnt stick and then he sent me another and the corners are still not sticking, and it is on the very very bottom of the bumper... im going to have to try again but it's such a pain!
Old Aug 8, 2010 | 01:33 PM
Empatho's Avatar
Mine is doing the same thing but only at the very edges, I'm just gonna drill a small hole and put a nut and bolt on there.
Old Aug 8, 2010 | 02:17 PM
6LITEREATER's Avatar
You also have to get it in just the right spot on the bumper. Little low or little high and you can press it on and it will look right for awhile but eventually pull away as the contour is shaped different.
Major PITA to find just the right spot since there is nothing to guide it off of but that's just how SLP designed it (not that there was anything else they could have done)...
Old Aug 8, 2010 | 02:45 PM
DaRReLL's Avatar
Maybe a plastic rivet like what is used on the front bumpers would do the trick?
