Brake calipers won't paint...help!!!
Old Nov 18, 2002 | 08:35 AM
jeff1vol's Avatar
Default Brake calipers won't paint...help!!!
Hey guys,
What kind of paint do you guys use to paint your calipers? I'm using plasti-kote engine enamel and it "separates" terribly. Thats the only way to describe what it is doing. I spray it on and after a couple of seconds the paint "separates" and doesn't coat the surface like it should. Any help would be greatly appreciated!!
Old Nov 18, 2002 | 08:45 AM
unit213's Avatar
Administrator
Default Re: Brake calipers won't paint...help!!!
You should run a search on 'Painted Calipers'. There is a lot of good info on past threads.
First and foremost, did you clean the calipers really well? I used a scrub brush and simple green followed by a dremel. I used a primer coat, 4 coats of paint, then 2 coats of clear. High temp paint isn't a must but you might as well do it since the paint isn't any more expensive.
Check out JMX's page:
https://ls1tech.com/howto/howto/inst...tcalipers.html
Let me know if you need further details. Here are a few of my install pics. Sorry for the poor quality.
http://216.112.25.134/poltergeist/Pics/camaro_ls1/2.jpg
http://216.112.25.134/poltergeist/Pics/camaro_ls1/6.jpg
BTW: The pics don't do the calipers any justice. They turned out awesome.
<small>[ November 18, 2002, 08:46 AM: Message edited by: camaro_ls1 ]</small>
Old Nov 18, 2002 | 09:51 AM
jeff1vol's Avatar
Hey thanks for the info. I thought it would be a paint and go type thing (cleaning included of course)! A bit more work than I had planned on...thanks again for the information!
Old Nov 18, 2002 | 10:01 AM
unit213's Avatar
Administrator
Oh, it's definitely not a "paint and go" type thing. It took me 6 hours on a Saturday just to do the front. Most of that was paint dry time though. You might want to check these out:
http://www.afterthoughtsauto.com/brakcaldec.html
They are a must. Good luck!
Old Nov 18, 2002 | 10:09 AM
JackZ28's Avatar
Cleaning is probably the single most important step. Paint won't adhere to an oily, or dirty surface! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 18, 2002 | 10:11 AM
SS 414's Avatar
It's definitely not a paint and go thing. I cleaned my calipers with brake dust cleaner and a wire brush. I used the Plasti-Kote high temp engine enamel paint. I think that's what you used, correct? I put a few coats on the calipers too. Mine took me all day to do.
Old Nov 18, 2002 | 10:13 AM
unit213's Avatar
Administrator
Not trying to over-do it here, but here's some more info:
https://ls1tech.com/ubb/ultimatebb.p...=002780#000000
https://ls1tech.com/ubb/ultimatebb.p...=000606#000000
Old Nov 18, 2002 | 10:50 AM
jeff1vol's Avatar
Man Im glad I started with the rears first! I'll be sure to clean those fronts REAL well! I've got caliper decals to go on and a set of E-Speeds, so the final touch is getting it painted! By the way... my right rear rotor did NOT want to come off! Unreal, had to get a rubber mallot and knock that joker off from the rear. Left rotor came off easy as pie!
Old Nov 18, 2002 | 11:05 AM
unit213's Avatar
Administrator
That's weird. My left rear wouldn't come off to save my life. The first time I pulled it off I yanked it as hard as I could and I flew back onto my ***. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> The next time I did it I pried it off with a screw driver. I placed the screw driver between the upper caliper guide bolt and the rear part of the rotor (protected with a piece of wood). It came right off.
Those eradispeeds along with painted calipers and the decals are going to look badass!
Old Nov 18, 2002 | 01:24 PM
WEASEL's Avatar
Some brake cleaner and one of those sanding sponge blocks work real well to just rough up the surface a bit. That or a 3-4" wire brush on a drill. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 19, 2002 | 12:49 AM
Mark IXZD 150's Avatar
Simple Green isn't a strong enough degreaser believe it or not. Use brake cleaner.
Old Nov 19, 2002 | 06:51 AM
JackZ28's Avatar
Wire brush, like Weasel said! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 19, 2002 | 08:43 PM
00SS4780's Avatar
If you ever look in a ricer mag. look at the adds and you will find caliper paint. It's buy fultac (I think that is how you spell it). It is a lacker paint and you brush it on. You can't screw it up(no runs or fish eyes). Later..
Old Nov 19, 2002 | 09:50 PM
TwitchBitch's Avatar
Stuff like armour all is silicon based and caused nothing but problems when you go to paint. Even if you have never armour all'ed your tires the dealership "slimes" all new cars with a cheap silicone crap and it has majour hangtime. The best way to get rid of this is with a true wax and grease remover like what your local bodyshop uses. Something like proform , tumbler, ppg etc. Silicone is stubborn to so you may have to clean them a few times , each time use new rags and dipose. I hate silicone <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Also if you are still having adhesion problems with the paint ( looks like its puddling and moving around spots, fisheyes ) , dust the paint on and have a blowdryer handy while your spraying. Once you get a couple light layers it will bridge the silicone.
