Detailing black trim
Old Aug 1, 2010 | 09:50 AM
00HAWK#068's Avatar
Default Detailing black trim
What do you guys like to use to detail exterior black trim? Just bought a new truck black on black with a lot of black plastic trim. Just want to make it look good without seeing it run in dirrect sun like some products do.
Old Aug 1, 2010 | 11:55 AM
dabest09's Avatar
I would also like to know. I've tried armor all but don't like it
Old Aug 1, 2010 | 12:48 PM
99zee's Avatar
I use VRT from Adam's Polish's. They just came out with a new formula that holds up better to water and the morning dew.
Old Aug 1, 2010 | 11:54 PM
99huggerorangeZ's Avatar
mothers back to black or meguiars mirror glaze(40) vinyl&rubber cleaner/conditioner
Old Aug 2, 2010 | 12:09 AM
jwill_20's Avatar
Default restore black plastic
First clean the part as good as you can. Use maybe dawn soap and some water and thoroughly rinse it off. Then take a heat gun and run it over the plastic trim back and forth and do not let it get too hot or too close! You can end up melting the plastic or the paint or parts around it!!! Its best if you can remove the part and then take the heat gun to it but if not just be extremely careful. After running heat over it for a while it will restore the plastic back to showroom condition. Its a simple procedure, just don't rush it, take your time
Test this process on a spot that is not seen first so you can see how it will look before you do it to the whole thing!
Old Aug 2, 2010 | 06:57 AM
aothepresident's Avatar
Bondo Restore Black, get it at any car parts store or wal mart. This is by far the best product I have used. It works more like a paint than an oil, truly restoring the trim's original color. Easy to apply as well.
Old Aug 2, 2010 | 09:23 AM
99zee's Avatar
WOW! that sounds scary. I'd like to see that.
Old Aug 2, 2010 | 09:36 AM
bj350hp's Avatar
x2 on that.
Old Aug 3, 2010 | 07:55 PM
5PONT7's Avatar
wash it good, Clay it well, and then wax. Just try it.
Old Aug 4, 2010 | 11:46 AM
SteelCityYaga's Avatar
Wash and dry like normal - if there is wax build up, try some IPA and some agitation.
Then try this:
http://www.autogeek.net/meguiars-ult...rotectant.html
You can find it at your local autoparts stores.
There are tons of products out there - you may have to try several until you get the results you want.
Good Luck!
Old Aug 4, 2010 | 01:27 PM
Screamin_99's Avatar
I always just use some simple tireshine for inbetweens.
