push button starter
Old Dec 15, 2002 | 11:48 PM
Constrictor 98TA's Avatar
Default Re: push button starter
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DWS44 2K2HAWK:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by spdracer:
<strong>i lke the idea of the push button starter, but would there be a way just to push the button and make that car start? where you would not have to use the key?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No flame intended, but why would you want it to work w/o the key? That would make it awful easy for someone to steal, wouldn't it?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not only that, but the key also disengages the steering column lock. You would need to take apart your steering column and remove whatever mechanism locks the steering column when the key is out, and then wire in a DPDT relay to simultaneously activate the Ignition power source at the same time as deactivating the starter. This would require more than just a button and a relay, you would need to design a circuit to do it, so that the ignition wire source stays on while the car is running. Then how would you turn the car off? Push the button again? Yes, it would be possible, but would require fabrication of a circuit to do it.
Old Dec 16, 2002 | 08:20 AM
2001SO1LESS's Avatar
Where are you guys ordering your parts from? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 16, 2002 | 10:13 AM
LS1Baron's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2001SO1LESS:
<strong>Where are you guys ordering your parts from? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The wiring and relay is available from Radio Shack, and the pushbutton is at the following site:
http://www.handa-accessories.com/s2000int.html
Old Dec 16, 2002 | 01:11 PM
Thanks! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 16, 2002 | 01:14 PM
I got a question!
To turn off the car do you just push the button again? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 16, 2002 | 09:50 PM
MOBE's Avatar
Constrictor!
Where did you buy the floppy drive power cable that you used? I think the Radio Shack one is going to be too big. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Also... Would you happen to know how I could wire it up so I could start it without having to push in the clutch, on my M6? I'm pretty sure there is a way. A buddy of mine has remote start on his vette with an M6.
...Doesn't hurt to ask! Someone might know. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks!
Old Dec 16, 2002 | 11:33 PM
WOJSS02's Avatar
Two Questions:
1) I was also wondering about how to turn the car off.
2) If you don't want a Honda Part on your car why not use the one from the new Viper? Is it too big or not compatible??
Thanks <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 17, 2002 | 11:26 AM
LS1Baron's Avatar
<strong>I got a question!
To turn off the car do you just push the button again? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No, you just turn your key to the off position. If you hit the button again, you'll have to replace your starter motor (probably).
Old Dec 17, 2002 | 11:56 AM
so to start the car you turn it to the on posistion then press the button, then to turn it off you just turn the key back?
Old Dec 17, 2002 | 01:41 PM
ws6-speed's Avatar
Mobe,
You would have to bypass the neutral safety switch. You can do a search on this site and probably find some info about that. You would have to run a relay so that the neutral safety switch is disengaged whenever the push button is engaged. Actually pretty easy to do.
As for the push-button, next time you start your car, notice that you turn the key to "start" then release and the key turns back towards you. That "start" position is what is being replicated by the button. The button has the EXACT same function as the "start" position for the key, nothing else.
Old Dec 17, 2002 | 01:53 PM
LS1Baron's Avatar
77-vette, I couldn't have put it better myself. This mod is one of those "cool factor" mods that are inexpensive and otherwise useless. That won't stop me from doing it, though!
Old Dec 17, 2002 | 04:01 PM
  #32
NataSS Inc's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MOBE:
<strong>Constrictor!
Thanks!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yup, anyone have a part number for the floppy drive power connector? Thats the only thing holding me back right now.
Old Dec 18, 2002 | 07:49 AM
  #33
ws6-speed's Avatar
mhulslan,
I agree! I love the mod and am waiting to get it done in a couple days. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
For the floppy drive cable, go to your local electronics store. Not bestbuy or compusa, but a real computer/electronics store. Take the button with you and they will be able to help you find something. It might take a fan power lead or something of that nature, but you'll find something there.
Old Dec 18, 2002 | 10:25 AM
  #34
LS1Baron's Avatar
Project update - security mount
I just had the mechanical engineering lab machine for me an aluminum sleve that fits the button. Also, they were nice enough to remove the pins and replace them with card edge connectors. Instant removable start button!!! Also, it's one hell of a security measure. Once installed, it will look like the lighter is missing. I'll try to get the CAD file for the sleeve for anyone else who has access to the gear to make one.
Old Dec 18, 2002 | 11:05 AM
  #35
ZYA_LTR's Avatar
Hell no that isn't rice, i'm gonna do it and cut the yellow wire so only the button will start my car, then hide the damn thing as a theft deterent device, hell, then you could just leave you r damn key in the ignition, when a buddy asks to take it for a ride, just tell him, sure man go for it, boy will he be pissed when he can't startit.hehe, then play along, like oh hell man, what did you do, the damn thing just started and ran all the way here.hehe
Old Dec 18, 2002 | 11:07 AM
  #36
ZYA_LTR's Avatar
awww damn mhulslan, now you've done it, another idea, now you gotta make these and sell them, i like that the best, great way to have a start kill switch. way to go man!
Old Dec 18, 2002 | 01:42 PM
  #37
<strong>so to start the car you turn it to the on posistion then press the button, then to turn it off you just turn the key back?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, that is correct. Your car turns off just like it normally does without the button.
Thanks!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">In addition to my passion for F-bodies, I am also a computer geek, and have been building PCs for many years. I usually have some spare parts lying around the house, and I happened to have an old power supply that I wasnt using for anything, so I just cut the power supply cable for the floppy drive off of it.
If you don't have any spare power supplies, look in your phone book and see if theres any computer parts stores in your area. Ask them if they have any old or non-working power supplied lying around and see if they'll cut off the power supply cable for the floppy drive and give it to you.
As for bypassing the clutch cutoff, I can't really help you as I have an automatic. I'm sure it's not hard though.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WOJSS02:
<strong>Two Questions:
Thanks <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm sure the Viper button would work, but I don't know of any aftermarket places that sell Viper OEM parts, and even if you found one, I doubt you would be able to beat Hand-a's price on the S2000 button. It works fine, and unless you run into someone who is familiar with the S2000, no one but you (and us) would know you had a Honda part in your car. Its not like it says "Made by Honda" on it or anything.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mhulslan:
<strong>Project update - security mount
I just had the mechanical engineering lab machine for me an aluminum sleve that fits the button. Also, they were nice enough to remove the pins and replace them with card edge connectors. Instant removable start button!!! Also, it's one hell of a security measure. Once installed, it will look like the lighter is missing. I'll try to get the CAD file for the sleeve for anyone else who has access to the gear to make one.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Now, that is a DAMN COOL idea!! I wonder how it would look when istalled and removed. You definitely need to take some pictures for us once you get it all hooked up!
Old Dec 19, 2002 | 12:39 AM
  #38
NataSS Inc's Avatar
I just had the mechanical engineering lab machine for me an aluminum sleve that fits the button. Also, they were nice enough to remove the pins and replace them with card edge connectors. Instant removable start button!!! Also, it's one hell of a security measure. Once installed, it will look like the lighter is missing. I'll try to get the CAD file for the sleeve for anyone else who has access to the gear to make one.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Please send me the file if you can!!!
Old Dec 21, 2002 | 04:27 PM
  #39
MOBE's Avatar
Push button is in, and...
ITS FOOKIN SWEEEEEEEET! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Dec 21, 2002 | 05:00 PM
  #40
spdracer's Avatar
is there any other type of button that you could use, i have decided to do this and really would like a blue button instead of the red one. anyone have any ideas?
dustin
