what coil covers are these?
yea, i dont see any reason why they wouldn't fit under the cowl, it would just be slightly higher than the coil packs themselves. You can run after market 2" taller valve covers (i use to on my old motor) under the f-body cowl so i would say the coil covers will fit with no problem.
Now, i have a question i hope someone can answer, do you think these coil covers will work on LS3 valve covers/coil packs? i know the coil pack bracket sits higher on the ls3 valve covers than on the ls1. Now that i saw these i want a set but dont know if they will work for my applicaton
you should look here before you consider buying them https://ls1tech.com/forums/appearanc...il-covers.html
looks like u need billet fuel rails, and i answered my own question, they will not work with on ls3 coils. guess im not gettin a set
