Question on t-top shades
I myself ran into the issue you mentioned with heat. Over time i went through like 4 sets of velcro, as they kept detatching from the glass due to the heat. Mine are currently painted. got rid of all the hassle, looks great, as if it came that way, and can easily be removed within 5-10 minutes should i ever need to. and it looks better from the outside than the shades ever did.
the way they're designed, you'll need to adhere them if you want to easily remove/insert the tops with the shades staying on all the time. without the shades being stuck with the velcro (or something else) it takes more time sandwiching the shades in between and getting it all positioned right when putting on the tops. which is okay if you don't take them off much. but it gets to be really annoying when you take them off all the time
i used to with one hand hold the shade and the other to hold the top when taking out and putting them in.
now i'll put the shade in first, and then slide the top over.
