LED's in fogs
Old Sep 28, 2010 | 12:35 PM
thecobrahunter's Avatar
X2 for 35W. The 55Watt bulbs bay burn/melt your housings. Plus, The extra heat generated doesn't justify the barely noticeable increase in light output.
Old Sep 28, 2010 | 09:16 PM
ssjason232's Avatar
sweet. gotta order the fog light kit now.
Old Sep 30, 2010 | 06:41 AM
ssjason232's Avatar
What bulb number do i order for the fogs? is it an H3?
Old Sep 30, 2010 | 10:27 AM
APG12's Avatar
Fogs are 880.
Old Sep 30, 2010 | 11:57 AM
FrankieD's Avatar
Does the HID kit require a separate switch and power source when installed or can the factory Foglight switch operate the HID's
Old Sep 30, 2010 | 02:33 PM
APG12's Avatar
Nope, just plug the kit in and youre good to go with the factory switch.
Old Sep 30, 2010 | 04:28 PM
FrankieD's Avatar
looking to order a HID Foglight Kit from DDMTuning..what bulb is used for the Camaro Foglights? (OEM stock bulb is 894) Is it the H8 or H9?
Old Sep 30, 2010 | 06:54 PM
SparkyJJO's Avatar
Did you not read just a few posts above yours?
Originally Posted by APG12
Fogs are 880.
Old Sep 30, 2010 | 11:49 PM
FrankieD's Avatar
I was unsure because the stock 894 bulb has an L-shaped socket and the 880 HID bulb has a straight shape socket. Thanks for double clarification.
