painting coils/ cleaning up coil area
Had some time so i tried to make the coil area more appealing visually on the car seing as i can no longer run the LS6 coil covers with my setup.
Before
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P1010004.jpg)
Coils pulled, and reason I can no longer run the ls6 coil covers
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9090176.jpg)
sent these to the parts cleaner and then a final wipe down with simple green
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9090183.jpg)
After 3 coats of VHT wrinkle finish paint (availble at autozone) plan on a LONG wait for drying (24 hours minimum)
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9100185.jpg)
some wipe down with simplegreen with the bolts and sprayed with semi gloss black and installed
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9100194.jpg)
Coils...not the most attractive..
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9100187.jpg)
Cleaning
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9100189.jpg)
Ready to paint
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9100190.jpg)
after a couple coats of krylon plastic paint
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9100195.jpg)
Harness with connector and clips sprayed semi gloss black and then wrapped with black electrical tape over the silver heat tape
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9110216.jpg)
re-assembled with stainless m6 allen bolts and washers from local hardware store (also painted coil brackets with wrinkle black)
Before
Cleaning
Ready to paint
![](http://i15.photobucket.com/albums/a380/mattc6/LS1%20Swap/P9120226.jpg)
1 Post
will that wrinkle paint mimic the stuff they sprayed in the back fenders of our cars? if it would id like to spray that in there to clean it up a lil bit under there and sorry to the op for thread highjacking lol
