paint problem...need help
Old Jan 28, 2004 | 12:33 AM
SSideExhLS1's Avatar
Default paint problem...need help
someone scratched my sail panel(roof panel between rear window and t top)
so i repainted it. its been through 4 different shops and 7 paint jobs and the piant cannot stick, it bubbles up after a few hours. is there a special process or products to painting this specific spot, any suggestions are welcome. thanks!!!
Old Jan 31, 2004 | 05:18 AM
BergerRefinisher's Avatar
Did you try shaking the spray can longer? Got to be in the surface....or a heat lamp too close?
http://members.aol.com/bergerrefinis...02/berger.html
Old Jan 31, 2004 | 11:13 AM
Danny2tek's Avatar
It has to do with the glue that GM used for the panel, they put out a bulletin about the problem..............
https://ls1tech.com/forums/showthrea...ghlight=bubble
Old Jan 31, 2004 | 01:00 PM
JohnS's Avatar
It may be the adhesive leaching through the plastic per the bulletin mentioned in Mustang5.Ohater's post, above.
I had to have my roof replaced. Pic's are at the following link.
Roof Repair
If it's not the adhesive problem, try epoxy primer prior to the finish coat.
