CME Question with SLP Powerflo Cat-Back
Old Oct 13, 2010 | 09:06 AM
Stealth Camaro's Avatar
Default CME Question with SLP Powerflo Cat-Back
Hey guys,
I just ordered my TSP 1 7/8", TSP ORY and SLP Powerflo exhaust
I also have a CME setup with tips from 6LE .. will the SLP elbow adaptor in the link below will make the powerflo exhaust work without any welding/cutting mods ?
SLP Elbow Adaptor : http://www.slponline.com/view_product.asp?P=310302010
SLP Powerflo Exhaust : http://www.slponline.com/view_product.asp?P=31083
Old Oct 13, 2010 | 09:42 AM
whytryz28's Avatar
Idk, you might need to move the mufflers farther back. I have a CME with a SLP LM1 and there isnt much straight pipe room behind the elbows, I was thinking of putting 2 mufflers/glasspacks there.
Old Oct 14, 2010 | 08:06 AM
pir7tr's Avatar
It can be done. I already had the duals and swapped the mufflers. My elbows were cut from existing 90 bends and then welded. There are 2 stainless clamps to remove before the rear wheel axle so the exhaust system can be disassembled. From the rear wheel axle back everything is welded. I suggest welding for noise reduction as well as preventing bolts from loosening.
