Buffing Tail Lights
Old Oct 26, 2010 | 06:08 PM
nichoLaS1's Avatar
Default Buffing Tail Lights
Can someone tell me how hard it would be to wet sand and buff the tail lights on a Trans Am? I am looking at buying a used tail light to replace my driver side lens (cracked and filled w/ condensation, i.e. black). I found one in good shape on this site, but it has a scuff mark that would have to buffed out.
Old Oct 26, 2010 | 08:34 PM
PontiacFan's Avatar
Do you have the power tools available? Porter-Cable or other machine?
Even a simple cheap 'Wal-Mart special' buffer would work.
Wet-sand with 1500-2000grit, then use some Plastic-Polish, which can also be picked up at WallyWorld.
If you are going to do it by hand, ..., Write-off the weekend, ...
I'd polish them all, to keep them all similar in finish also.
Old Oct 26, 2010 | 08:44 PM
Trans Am Jam's Avatar
hey my dude, here's a thread I made awhile back..hope it helps.
RECONDITIONED TAILS
Old Oct 27, 2010 | 05:53 AM
nichoLaS1's Avatar
awesome, thanks a lot guys.. I'll def be following that write up..
Old Oct 27, 2010 | 01:31 PM
Striker's Avatar
Depending on how bad they are, I dont think you will need to actually wetsand them. Judging by the pics you provided, I think your lights are fine and should finish nicely with a Porter Cable and some paint polishing compound.
Old Oct 27, 2010 | 03:10 PM
red4.8's Avatar
Tail lights buff out pretty easy. If sanding is needed, I would go with a high grit..
