What to do with nitrous bottle
I currently have my bottle where the spare tire was. I need to get it out in the open for car shows. Any ideas on where to put it. Need something to liven up my dull hatch area.
Re: What to do with nitrous bottle
I have a 15lb bottle on the back deck where the child seat hooks are, because i've got a box with 2 12's in the well where the t-tops go. All you have to do is get a torx head wrench and take either one out and put the bolt back through the hole in your bottle bracket. Angle the bottle to the back and let it rest against the fold up divider. Run your line under the plastic w/ your rear speaker, down the side of the rear seat, and,since my valve is on the driver's side, there is a rubber grommet under the bottom of the rear seat. Unbolt the seat and run the line through a small hole you have to cut in the grommet, and run the line down the fuel rail, out of harms way.
