Body guys, how much to get something like this fixed
I had a similar thing happen to me. I was told dry ice would do it but it would make the paint come back. Insurance did only because it wasnt my fault. The payer was charged 1600.00 dollars to fix it.I knew someone at the body shop so I removed the back bumper and taillights and the fenderwell myself and he fixed that side and the other side for one sides cost. I then put the stuff I took off back on myself. But unfortunately, a neighbor kid hit it with a rock and put a dent in it. Cannot prove who did it though. I am working on a front bumper right now though for free.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by craiG's SS
If u take that to a body shop and they say they need to put a quarter on it, instead of fixing it then they dont know what the hell there doin! Grind the paint off take a stud gun to it and pull it back out paint it and blend it into the door, and call it a day
I own a body shop, the paint alone is the most costly part of the process. That red is about 65.00 a pint. Have a shop blend the door and the quarter panel. Don't spend over 4 or 5 hundred, I would do it for about 400.00, Wish you were close I could use the business !
GOOD LUCK and sorry that you bent your quarter.
i could pull that my self and im 18. u dont need a quarter panel put on, but somepeople would rather do that because they dont want a damaged part on their car, even if its a perfect job on the outside. if u got ur car used ur in danger of this ne way so it doesnt matter.
and i would say its possible to get quoted on 2500, i just read on another board, someone was quoted 1500. if it was to be replaced, blended into the door, have the lock and handle remove, i would bet labor could go that high. but no way in hell an estimate that high should be leagle.
Well, I got good news and bad news........
First the good, the panel can be fixed..........
The bad news.
Got the first estimate done. Here is the short version.
Parts 28.32
Body Labor 11.4hrs@44.00hr 501.60
Paint Labor 7.3hrs@44.00hr 321.20
Paint Supplies7.3hrs@25.00hr 182.50
subtotal 1033.62
tax 60.08
Total
1093.70![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
FU@K Well time to head on out to get another estimate done, and that was done at the place that did the work on my dads van, thought they would like return customers.
Jeremy
The bad news.
Parts 28.32
subtotal 1033.62
tax 60.08
Total
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Jeremy
I have similar damge on my TA.(G-friend backed into it) I found out that it would be harder to replace that piece. From the doors on back is one piece. Said you would have to cut it off and then weld a new panel on. Mine is actually worse then that one.. Damn, wish i had a digital camera.. Might try to pull it myself. Hell, dont think i can make it any worse.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Wow, thats one hell of a dent for a slip and fall.............
I had something minor like that happen, but it was just a scratch from another car that created a dent/scracth type of deal, it was about 600 total to fix with new paint, the quarter panel was still all good, glad it didn't crack...
It sucks that it had to happen now when we are trying to get things rollin....
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
I had a similar accident when a girl back in to me. Took it to the body shop and I was quoted $1200, but after they finished they ended up charging me just under $1000. Good luck getting her fixed.
#32
I got two more appts for estimates tomorrow. The other two good places that I would trust with my car does estimates by appt only![Gay!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_rainbow.gif)
Hopefully I will find something a lil cheaper. Good thing my tax money will be here on the 20th
Gotta stop being a looser and find a job already![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Yeah Bos, did my ol car real bad with body weight and a elbow(elbow=small dent, big dent I guess was my hip) Check your PM's.
J
![Rock](https://ls1tech.com/forums/images/smilies2/rock.gif)
J
#33
waterbug actually u can make it worse. dont try to pull that quarter off if u never welded befor. i know i wouldnt want to clean up ur mess if i was the body man, for cheap. tearing up the qp where its welded together will make it harder to take off. plus if uve never dont nething like this its not a do it ur self thing. it takes lots of tac welding in place, readjusting then readjusting. then putting the deck lid back on or close it, check the gap, check the door gap. quarter panels are the one thing i would not sugest ne one to do with out body work experience. take it it if u want it done because most shops will be able to pull the dents.
#34
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#35
A friend of mine rubbed his front bumper against my car in the same exact place that your damage is... Your car looks just like my car did, except my driver's door was a little bit scuffed up. Body repair, paint door and 1/4 panel, $950.
#37
Agreed with the post above to have it fixed around $500-$600. I had the passenger side all f**ked up thanks for a neighbors kids scooter which left a good 18-24" scratch and nasty dents, not as bad as yours but pretty messed up. If you take it to a good place you wont even notice it.
Unfortunately my deductible was $500 so it was not even worth going through my insurance. Most places give a cheaper price if your paying and insurance isn't.
Dont have a before but do have and after:
![](http://www.baxtersystems.us/camaross/images/mods/!antenna.jpg)
