What headlight bulb are you currently using?
Yeah no scatter... at all...
What HID's in a proper projector housing should look like with a proper cut off.
And;
35w HID H1 5000k.
........................................ Not running V these anymore. Old pic. Some halogen housings aren't as bad as others with HIDs in them. Some are absolutely horrible. The worst ones are usually the dual beam light housings, because the reflectors are designed with dual focal points from the high and low filaments. Well, the HID tends to reflect off the high beam reflector points, making it that much worse for other traffic.
a 35W HID is around the same lumen output as a 65W halogen high beam bulb. If you like bright lights and don't care about other traffic, why not just drive around with your high beams on all the time? Similar effect
Last edited by SparkyJJO; Feb 17, 2011 at 04:33 PM. Reason: Corrected grammar mistakes from being too tired
Even though the road is lit up very well, look at the houses at the end of the block.
Yes, I know, I'm an *******. But that's what I need to be able to see, unless you wanna buy me a BLS kit
MOVING ON.. Whatever you do, stay away from Sylvania.. haven't had any luck with their stuff. The "XENON" bulbs were yellowy brown. The "ULTRA 50% BRIGHTER" or whatever it was, WASN'T brighter, and a silverstar blew on my 3rd gen when I had it.
Just trying to save you some misery lol. Good luck
Uhh yeah, thats why high beams are for buddy...and if stock their not bright enough for you to see I don't think you should have a license..
Go resurrect another thread you useless piece of ****.
