Trans Am Diffuser, CETA area, installed...
To be honest, it drives me insane when people e-mail and ask, "I have a show in two days, if I order this tonight will I get it by then...?" NO!!!!!!!!!!!!!!!!!!! Lol.
If you want something order it and you'll get it as fast as you can possibly get it regardless, no what I mean?
That said, as of RIGHT NOW, there are one or two CF diffusers left in stock ready to ship...
* Did you all sand it a spray it with a matte black spray? Mine is a bit rough and would look better if I spray it.
* Did anyones come predrilled with the holes in the license plate?
* Did anyones come with double sided tape? You would of thought for the price it would have.
* How is your fitment? Did anyone have to bend the ends in to conform with the bumper? I f I hold mine where attached to the license plate both ends stick out away from the bumper and you have to push it in to sit on the bumper. I don't think double sided tape is going to hold it
* Also for the install, did you remove the bumber to install or do it with the bumper on?
Holes are not pre-drilled as everyone's seemed a little different...
It SHOULD have come with double sided tape and two screws (for the bottom side). I just found out the company isn't sending that or the instructions (they just messed up) so buy that stuff and I can re-imburse you, future orders will come with it....
It does seem to bow out but once you mount with license plate you and 3M you put as screw on the bottom (unseen) on each side and it holds just fine. It conforms after a couple days in the sun...
No need to remove the bumper. We installed three in about 10 minutes each on the cars. Just need to jack it up high enough to get a drill under it...
Would you recommend a double sided tape? Any one hold better then others?
Also, would you use screw underneath or a nut and bolt type?
