Another Dot Matrix Question
Old Mar 21, 2011 | 08:19 AM
Sladester2's Avatar
Default Another Dot Matrix Question
Hi, I'm new to these forums but I've read around on them a bit.
I know most people fix their dot matrix tint problems with some vinyl. I was wondering around how much its going to cost to get a tinter to lay the vinyl on it.
99 nbm trans am
Old Mar 21, 2011 | 09:02 AM
99_Z_155's Avatar
99 nbm trans am
I think mine was like an extra 25 maybe? that was like 3 years ago.
Old Mar 21, 2011 | 09:57 AM
thecobrahunter's Avatar
$25 sounds about right.
Old Mar 21, 2011 | 11:22 AM
4get gto's Avatar
99 nbm trans am
Where you from Sladester2 ?
BTY I had mine done without any problems with just tint.....Just depends on the installer I guess........
Old Mar 22, 2011 | 11:15 AM
1LOMARO's Avatar
Another way that helps with the dot matrix issue is to let the car bake in the sun. I went out twice a day and used a credit card to smooth out the areas that were trying to not lay down. Might work for some... might not. I think the quality of the tint also helps.
Old Mar 22, 2011 | 05:42 PM
karpesh29's Avatar
My tint guy did it for free, but 20 bucks or so sounds about right for the small amount of vinyl and 5 minutes it takes to do.
Old Mar 22, 2011 | 06:03 PM
nascarnate326's Avatar
Can you paint or nightshade the dot matrix?
Old Mar 22, 2011 | 06:06 PM
Empatho's Avatar
My tint guy torched the window and it hasn't bubbled up.
Old Mar 22, 2011 | 07:56 PM
Lotus289's Avatar
Yes you can. I painted the inside of my glass and just tinted right over it. Came out great!
Old May 25, 2011 | 02:15 PM
djfury05's Avatar
looks good.. has anyone painted their hatch with it still on the car?
Old May 25, 2011 | 02:58 PM
Swiat34's Avatar
I painted mine on the car. Just mask everything off. Had no problems with doing it that way. I think this is the 3rd thread on this exact topic this month. Unless the search wasn't working, you should be able to find a lot of answers with research. Besides that, the guys that say the tinter applied over it, the tinter may have sanded the dots a bit. Less bump is less likely to cause bubbles. I couldn't imagine applying vinyl wouldn't make a line bubble where the tint overlaps it. I'd say paint it and then lightly sand the edge of the paint.
Old May 25, 2011 | 04:58 PM
95TAJade's Avatar
Just ask the tinter you take your car to; to sand the porcelain bot matrix down a little bit wit a DA or you can have them use an OLD tinter's trick and use a glue stick on it. The tinter at the shop I work at hates doing the back glass on cars like ours; but he gets the tint laid looking all clean and no bubbling around the dot matrix
