DRL wierd problem
Old Mar 23, 2011 | 05:53 PM
pimpjames's Avatar
Default DRL wierd problem
So I took the switchbacks out of the trans am after it stopped my drls from running and put some regular bulbs in. Now the issue is my right one is working properly however the left one doesn't work on the drl's but has the high bulb on for parking lamps. Turn signals work as they should on both as well as hazards. Think there is a wiring problem?
Old Mar 24, 2011 | 11:34 AM
pimpjames's Avatar
This not the right section maybe?
Old Mar 24, 2011 | 07:54 PM
pimpjames's Avatar
Another update *Obviously to myself...* Def. Seems like a wire somewhere becuase I noticed today that when I use the left turn signal the guage cluster and etc. lights up with it as if the light switch is enabled.
