Tired of that nast gap under the headlights?
Where did you get the stuff you used to fill the gap? I'm looking for some CF to make a sort of a fog light bezel on my girls car I need it to have a very small amount of flex to it so it can contour against the opening I want to place it against but I still need it stiff enough to be able to mount the fog light in it and not flex when the wind pushes against it while driving if that makes any sense lol.
![](http://img.photobucket.com/albums/v225/9secZ28/Stacey/TypeSDropped2-1.jpg)
I have'nt made any for a while. The peice of glass I made it on broke. A 4'x4' peice would be around $275+/-. The carbon it's is usually around $40 per/yd plus the resin, peelply backing and release agents. My shop rate is $50 per/hr and it would take about 2.5 hr or so.
#32
every little bit helps. Aerodynamics start coming into play @ 40 mph. My next project is to make a diffuser panel. I've made them before...just not for my Camaro. Hopefully that will help a little to, it always did on our race cars.
