Cleaning Torq Thrust II wheels
here is meguiers
the last couple of times i had cleaned them though i used griotts magwheel polish and it did a good job as well.
but the most important thing is time and elbow grease and for me i found i did a better job if i took the wheel off and cleaned them
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Meguires polish is among the worst I've tried, mother's paste polish work ok but takes a ton more work than a good liquid/watery polish.
I would take Adams/Blingmaster/other watery liquid polish over ANY paste (Mothers, Meguires Hot Rims, Eagle 1, etc)
You use a dime sized drop on an inside out sock and work 1/8-1/4 wheel at a time and it works fast and easy. Last time I used some Blingmaster on a powerball mini and that also works great and took about 5 minutes per wheel.
