mgw shifter owners !!
Old 05-28-2011, 11:20 PM
tripblackls1's Avatar
do you love your shifter?
do you hate the crappy stick that your stuck with ?
i know i completely disliked my mgw stick and the placement, so i busted out some 5/8 steel rod and 3/16 steel plate and got to town!
i adapted my aluminum Hurst stick and ball to my mgw shifter and in the process, i positioned it where i wanted it!
heres the pics
pretty simple and easy, it took me about an hour of fab'ing and test fitting and the results are amazing, i finally have my shifter where i want it !
pls dont mind the mess in my car lol
Old 05-29-2011, 05:09 AM
WSSICK99's Avatar
my body has mgw in is mustang and i had pro 5.0 in my old stang and i could shift ten times faster with my shifter
Old 05-29-2011, 10:40 AM
what?
this is not about which ones better .......................
Old 05-29-2011, 10:54 AM
IWGF's Avatar
I actually like where my MGW stick is at on the shifter... No thanks.
Old 05-29-2011, 11:03 AM
that's cool man, i like to have my shifter as closest to me/the steering wheel as possible and the mgw stick just did not cut it, plus with this you can use any type of stick you would like and it adds tons of adjustability
Old 05-29-2011, 11:29 AM
truekoa's Avatar
wheres your e brake?
Old 05-29-2011, 01:27 PM
dont have one and dont need one
Old 05-29-2011, 01:50 PM
pewter2002's Avatar
Is this setup heavy? I was just wondering that if it is heavy and you shift with authority that you could over "throw" and damage/wear out something in the trans? Maybe you can adjust the throw stops to ensure this does not occur? Not an issue perhaps? Just wondering, I like the idea of setting up your car for YOUR taste/requirements!
Old 05-29-2011, 02:41 PM
My stick is lightweight so this setup weights as much as the mgw stick, also the t56 has internal stops so overthrow is not a problem
Just took the car for a short 30min drive and its pretty amazing
By far one of the best mods I've done
Old 05-29-2011, 03:22 PM
scj
scj's Avatar
this looks really gaudy and dumb. to each their own.
Old 05-29-2011, 04:50 PM
are you serious? once the shift boot is on you dont see it!
i guess ppl on here that own mgw shifters dont drive there cars because the stick/position you get with it is horrible
with this my shifter is almost four inchs closer to me then with the stick that came from mgw
Old 05-29-2011, 05:51 PM
tbird31's Avatar
I had an MGW shifter for a long time. Loved the stick placement and position. I like it better then any other shifter honestly, the only reason I upgraded is because I went to a Hurst Competition Billet for the looks. I don't know why you didn't like it, most shifters have the stick positioned on the right side of the boot, I liked how it sat on the left side closer to the driver.
Old 05-29-2011, 06:02 PM
firemech21's Avatar
Honestly, I think its a good idea. Adapt, improvise, and overcome. If it works good then good on you for making it better for your needs.
Old 05-29-2011, 07:04 PM
thank you sir
Old 05-29-2011, 07:06 PM
hmm interesting idk why but the stick sat very far away from me on mine, but now its closer
Old 05-29-2011, 09:29 PM
Empatho's Avatar
That's pretty cool, and like you said its not going to be visible from once the boot is on.
Old 05-29-2011, 09:49 PM
yep and if anybody else wanted to do this they could literally put the stick anywhere they wanted and any height they want
they could also make there adapter a lil prettier if wanted, i just threw some scrap metal that i had laying around together with my elcheapo weld because i was unsure how well my idea was going to work
but it works awesome !!
Old 07-03-2011, 09:56 PM
oldmano2z's Avatar
tripblkls1, nice job on the adapter .i made a dogleg for my hurst pistol to position it just in front of my console hurahh for inovation!!! good to see young guys inventing things instead of just looking thru a catalog [nessesity is the motherhood of invention!] keep up the good work.
Quick Reply: mgw shifter owners !!
