LS1 T/A style bumper on Camaro?
yes something like that but a little clearner. Not the rear tho that looks UGLY
dont trip off that fool nor even wast your key strokes LMAOOO
Ive seen that pic before but I want to find a cleaner looking one if there is one out there???
i dont understand? with the extra 3 seconds, im assuming you could've explained to me where i should "line up the grilles/license plate area properly?"
and like Jam said, im not spending hours on this thing, i put this together in maybe 30 minutes? looks fine to me, i do understand that its not perfect, but im ok with that.
lol @ that picture McNord. i thought the same thing when Zee mentioned that! hahaha![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Sorry, I can't help myself sometimes. I've been using Photoshop since version 5.0, so I get bugged more than others when I see something that's "off" and only takes seconds to fix.
Revision to "Catfish". I moved the grille down a tiny bit and enhanced the detail on the grille:
![](http://img339.imageshack.us/img339/7963/catfishu.jpg)
Revision to "Goldfish". I redid the chop completely using a pic of an Arctic White TA front end. Still off a little bit, but a lot closer to the body centerline, and the colors are still ok:
![](http://img841.imageshack.us/img841/8679/goldfish.jpg)
Honestly, i can see the difference, but i dont think it really makes a difference. Still looks good to me either way.
#34
FUPA is...Fatty upper ***** area. Not front upper ***** area. Only fatties have FUPA's...well, I have seen skinnier ones have them too. It's usually older women after giving birth. You all have seen them. They wear the tighter jeans nd you look above the sugarhole and see a big bump.....it's disgusting. http://images.ibsrv.net/ibsrv/res/sr...ch/gr_barf.gif
