What is this hose for?
Old Jun 28, 2011 | 11:07 PM
SpeedDemon02SS's Avatar
Default What is this hose for?
Under the hood, the hose that is on the drivers side over the fender. It looks like poop and I want it gone. What is it, and how can I do that?
Also, the air hose that goes into the air lid. Can I remove or relocate that?
Old Jun 28, 2011 | 11:35 PM
jsteele90's Avatar
all those hoses are part of your air system and yes you can delete all of that
Old Jun 28, 2011 | 11:41 PM
i fi dont want to delete it, can i relocate it?
Old Jun 28, 2011 | 11:46 PM
cowboysfan's Avatar
check with local inspection laws first, not sure what kind of emissions test you got in that state.
Old Jun 28, 2011 | 11:47 PM
jsteele90's Avatar
yeah you can cut it and stick a breather filter on the end hide it nder the car. and plug the hole in the air lid
its not the emmission laws i am concerned about (in NJ they just plug into ODBII to check for codes. no sniffer), its the constant SES light on that will **** me off.
Old Jun 28, 2011 | 11:48 PM
jsteele90's Avatar
pics would help greatly
Even the one that goes over the fender? Where is that going to/coming from?
Old Jun 28, 2011 | 11:51 PM
jsteele90's Avatar
it goes to the air pump and the only way to get rid of it is to eliminate the air system. just get it tuned out if you dont want to deal with the ses light
Old Jun 28, 2011 | 11:55 PM
I am making a day of it and cleaning under the hood. Already know how to relocate the TCS and wire harness on passanger side.
Old Jun 29, 2011 | 10:09 AM
ssteven's Avatar
Attachment 303314
Thats the airhose/supply to the back of the motor for the manifolds. Yank all that crap off. You can have the AIR pump tuned out , pull the fuse or leave it on(under the headlight) Cap off the lines and the intake.
Old Jun 29, 2011 | 10:30 AM
Xsta Z 28's Avatar
I ran mine, including the hood release through the drivers side fender well . . just like the !wire mod for the passenger side shock tower.
Old Jun 29, 2011 | 10:33 AM
Xsta Z 28's Avatar
Pics:
The hose that goes to the air box, was shortened, and a little breather filter added below the fuse box.
The air pump is located just behind the driver side fog lamp. . . . once you remove the wheel well liner everything is accessible, and you can see how the relocate a mini filter, got one of the silly "ricer" breathers from Autozone or Pep Boys. Shortened the OEM hose and clamped the filter on . . The got some plastic hose bars from ACE to assemble the AIR hose through the wheel well. I unfortunately did not put a liner around the hose, so when it is a bit chilly the hose squeaks as it rubs on the metal support.
I enlarged an existing hole in the fender support with a Dremel to feed the hose and hood latch through.
Old Jun 29, 2011 | 10:54 AM
Nice. That's what I'm gonna do. Thanks.
Old Jun 29, 2011 | 05:08 PM
drone's Avatar
I just yanked all that crap out. tuned light off with efi live.
Old Jun 29, 2011 | 05:11 PM
Latch's Avatar
Originally Posted by Xsta Z 28
I wish my engine bay looked that good. Well done sir.
Old Jun 29, 2011 | 05:23 PM
Pete137's Avatar
If you REALLY want to keep it, then fine, hide the hose.
But in my opinion, take it off! The air injection system runs for a little bit after a cold start to help get the cats up to proper operating temperature. It's practically worthless, ugly, and adds unnecessary weight.
Old Jun 29, 2011 | 05:31 PM
It's not that I necessarily want to keep it or not. I am not working right now, so I am looking at free things to do. If I removed it, I'd have to get a new belt, tune, and plate for the manifold. Just easier to keep it. I'm not fast enough that the weight savings would even be noticeable.
Also, does anyone know where I can get rubber grommets for the wire mod and this mod?
