Back Seat
Old Mar 25, 2003 | 02:44 PM
Rice Burner's Avatar
Default Back Seat
I want to remove my back seat, along wit seat belts, and the two ***** that stick out which lock the back seat in place, and anything else associated with the backseat. How do I go about doing this. I was just going to start taking things apart, but I thought I'd try to make it easy and get a step by step.
Old Mar 25, 2003 | 04:00 PM
Default Re: Back Seat
anyone?
Old Mar 25, 2003 | 04:06 PM
Xsta Z 28's Avatar
1. Remove the seat "buns" I believe 13mm blots facing forwar, somewhat centered at the very front bottom of the seat "bun"
2. Fold the back seat down and remove the seat belt loops from the seat back. They are a Torx bit and are VERY difficult to remove
3. Fold seat back up and remove two 13 mm nuts from the hinge points, one at each lower corner. Then the seat back comes out.
4. Seat belt reveivers are abig Torx bit.
5. The seat back latches are also big Torx bits.
6. The seat belt - dunno, never took then out before, although in a convertible they are A LOT easier to get to than a coupe.
Old Mar 25, 2003 | 08:03 PM
Thanks. Ill post pics of what I plan to do with the space when it is actually done.
Old Mar 26, 2003 | 09:26 PM
SSpilot's Avatar
I was thinking about doing the same, can't wait to see the pics
