H9 to H11 Conversion??
Otherwise its a minor change. If you look at the connector at the base of the bulb, you'll see that the small plastic tabs on the inside between the metal prongs are slightly different and need to be trimmed. I don't remember if the tabs on the "lock ring" part of the bulb need to be trimmed.
