Need monster tach pics.
Please don't screw a big ole tach onto your dashboard. Nothing screams 1985 than having a great big tach there. I knew a guy who put a monster tach in his automatic, which I could never understand.
Chris
If it meets those two rpms, then set it to whatever you want it at and it should work. The problem with the factory tach isn't that it's innacurate, it's that it's slow moving, especially when you change gears, and add more power. It's the motor that drives the needle that's slow and can't keep up. So if you slowly rev the motor and hold it at an rpm, it will display that rpm on the tach.
So get a new shiftlight, install it properly, make sure it's at the correct rpm, and you should be fine.
