got Brakemotive rotors? post ur pics plz
#41
Yes, the package will include an installation guide, but here it is:
The break in procedure is critical to brake performance. The reason for a proper break in is to establish an even layer of friction material deposited on the rotors from the brake pads. It is very important that this initial layer of friction material is evenly distributed. Break in the pads as follows: 5 moderate to aggressive stops from 40 mph down to 10 mph in rapid succession without letting the brakes cool and do not come to a complete stop. Then do 5 moddumerate stops from 35 mph to 5 mph in rapid succession without letting the brakes cool. You should expect to smell some resin as the brakes get hot. After this is complete, drive around for as long as possible without excessively heating the brakes and without coming to a complete stop (Try for about 5 minutes at moderate speed). This is the cooling stage. It allows the heated resin in the brake pads to cool and cure. After the brakes have cooled to standard operating temperature, you may use the brakes normally.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#43
#44
To everyone that has these rotors do you all coat the rotor hub with somekind of paint to keep them from rusting or do these rotors have some special coating that prevents this? I'm getting me some this week and wanted to know if I should buy some brake paint or not.
#46
#47
Location: Your girl's back door giving her the long stroke while you're at work
#56
