Installing shorty antenna, help!
Old Sep 20, 2011 | 08:05 PM
Tan327's Avatar
Default Installing shorty antenna, help!
I'm trying to install the shorty antenna in the pic below, but I'm a little stumped on how to separate the part that the antenna screws onto from the black plastic piece. Does it just unscrew from it? I tried pliers but they slipped(need vise grips if it does in fact unscrew) ..anyone else use this antenna? Any help is appreciated.
Old Sep 20, 2011 | 08:09 PM
silversrtman's Avatar
i have that same antenna, i just took off my stocker and replaced it with that one....didnt use any of that other stuff
Old Sep 20, 2011 | 08:11 PM
Tan327's Avatar
How did you get it to screw all of the way onto it? Mine screws like half way and leaves a gap.
As you can see the bottom of the antenna mount becomes narrow towards the top, that's where the problem is.
Old Sep 20, 2011 | 08:45 PM
00FlowCamaro's Avatar
You shouldn't need to do anything. I have had two camaros and they both got the same antenna you have there and they screwed right on.
Old Sep 20, 2011 | 09:03 PM
Tan327's Avatar
Lol, no way ..I wonder what the deal is with mine? They screwed on by hand? Mine seriously stops less than half way and won't budge(just scraped it up trying with pliers, even had them covered with something )
The simplest job can be so frustrating ..guess I could cut threads off..
Ended up using a couple of the pieces, turned out decent.
Old Sep 21, 2011 | 12:58 AM
98blkz28's Avatar
is there not a gap filler? i got an ebay stubby and it went right on
Old Sep 21, 2011 | 02:14 PM
yeah i didnt have to do anything other than screw it on...no problems...you should contact the place where you got it, maybe the threads are screwed up?
Old Sep 21, 2011 | 04:07 PM
Lizard King's Avatar
So you got it on? Did you use that little black piece that comes with it? I only got mine half way down like you until I tried fitting the black piece with it.
 Michael S. Palmer
Old Sep 21, 2011 | 10:45 PM
emenny81's Avatar
I used one of these, I would take pictures but my car is getting painted
http://www.homedepot.com/Bath-Bathro...atalogId=10053
Old Sep 22, 2011 | 12:05 AM
PwrHngryLT1's Avatar
They usually come with like a plastic spacer to fill the gap if there is one. I see that in the picture you have what looks like a long plastic spacer. You could cut it to length to have it cover the gap or somethings up with the threads (such as damaged or threads dont match).
Old Sep 22, 2011 | 01:10 AM
98blkz28's Avatar
if i can find my pieces i can mail them to you
