Driver side wire tuck WITHOUT extending the harness!
Old Apr 25, 2013 | 08:38 PM
FrankSS's Avatar
I'm doing this now... How did you get the plug off of the firewall to run down under everything? That's the only thing holding me up...
Old Apr 30, 2013 | 06:13 PM
Firebirdmuscle's Avatar
Anybody else have more info on this and any more pictures. How will the abs wires come affect? And what about the wires that run under the air lid and go to the pass side? Where have y'all routed them, along with them still being long enough to not put tension on them with the pass side wire mod done
Old May 19, 2013 | 10:33 PM
Does anyone know what the wires are that run right beside the top of the fender that go into the cowl? I have the harness pulled into the engine bay but those few wires running into the cowl all the way on beside the fender have my at a stand still
Old May 19, 2013 | 10:36 PM
djfury05's Avatar
Wipers I believe
Old May 19, 2013 | 11:31 PM
Where is the disconnect plug for that located at
Old May 20, 2013 | 07:28 AM
FrankSS's Avatar
It's underneath the plastic cowl... You will have to pull the DS wiper to get to it I believe.. I removed mine so I don't have to worry about it anymore. I'm almost done with mine, and relocating the PCM into the windshield cowl to clean up the wiring even more
Old May 20, 2013 | 09:38 AM
Okay thanks. I have the harness in the engine just sitting but this is the last one I need to undo
