Another Painted LSX
http://community.webshots.com/user/wahusker
Mark
Good Job!
What size opening is that on the intake?
It's the 78mm version. My motor is stock, so it's all I need. I hope to dyno next weekend.
Painting plastic is a complex process. You need to wipe it down with a cleaner to get all the oils off. Then you apply stuff called Plas Stick to make the primer stick. Then you prime it. Then you paint it. Then You clear coat it (if desired). I used regular car paint. The plastic intakes don't get that hot.
