Switch panel (with pic)
Old Mar 9, 2004 | 09:03 PM
jlaw's Avatar
Default Switch panel (with pic)
I picked up one of these last week and I'm very happy with it. A fellow forum member (his forum name is "slow") makes them and the quality is top notch. It fit perfectly into that small opening in front of the shifter and looks clean. I had mine set up to control my line lock, fans, and cutout, but I believe he can set the panels up in multiple configurations.
Old Mar 9, 2004 | 09:25 PM
14u2nv's Avatar
I thought that switch panel was made by Nitrous Express?
Old Mar 9, 2004 | 09:55 PM
jlaw's Avatar
This one isn't... NX sells one with SPDT lighted, SPST momentary, and DPDT momentary switches. Great for n2o, but that's about it. I got mine configured with the switches I needed for my setup, something NX doesn't offer, and this one didn't cost $70 like the NX one.
Old Mar 10, 2004 | 04:14 AM
SSactionLs1's Avatar
the NX one is 50. ANd you can ask for whatever switches you want.
Old Mar 10, 2004 | 08:10 AM
jimmyblue's Avatar
Moderator
That's pretty. I would need one of those positions
to be the convertible top switch though, which would
break up the theme. Three matching OEM-style switch
caps, though, and I would just have to have one.
Old Mar 10, 2004 | 08:48 AM
RyanJ's Avatar
SSU Moderator
why not make one of the above switches run your conv. top.
Old Mar 10, 2004 | 09:14 AM
slow's Avatar
really? can you please send me information on how to get them custom from NX? I have not heard of that before,
Also map is $57.99 on the Nx panel, so no, you won't be finding it from authorized dealers for $50 shipped.
Ryan
Old Mar 10, 2004 | 01:09 PM
jimmyblue's Avatar
Moderator
The OEM convertible top switch is a funny custom critter
and a straight SPDT/DPDT I don't think is going to work
as a plug-in replacement. Maybe with some rewiring. But
it also has to be a pretty beefy one, 30A or better.
 Michael S. Palmer
Old Mar 10, 2004 | 08:20 PM
slow's Avatar
The factory vert switch, is like a power window switch, that holds ground to all the terminals, and when pushed, changed the ground, to +12 volts of one wire to complete the circuit.
You could simply rewire it to a standard DPDT switch, and it should work, if I am reading that schematic correct, as there are just +12 and 2 grounds going into the switch, and 2 wires leaving it to the motor.
The switches shown are rated for 20 amps, not sure if thats enough or not. 2 relays could easily be used to make it work, if your game for that kind of rewiring, but that is above what most people will do, for a simple mod like this.
Ryan.
Old Mar 10, 2004 | 08:44 PM
Toonz's Avatar
I'm currently using a factory vert switch for my cutout, and the factory tcs switch for my line lock... not bad, but I kinda like the setup above as well. May have to look into changing a few things. Thanks for sharing the info!
