how much will dynamat help with keeping mycar cool?
, but I'm wanting something with the power that I want plus to be comfortable at the same time. Essentially, it's the layer of aluminum foil, if you want to call it that, which acts like a thermal blanket keeping out heat. It works. Ask the turbo guys who wrap things around their turbo's with the stuff.
I imagine if you put some additional heat shielding underneath your car (and/or peel/stick some sort of insulation to the factory heat shields), that would help as well. I just bought a HUGE roll and cut the pieces to fit. Used the leftover material for front+side+rear window privacy shades/minor heat insulation since it looks like the same material used to make windshield shades.
